First time pool owner. First test using the Taylor K-2006c test kit. My pool is cloudy in deep in. I can see drains but it’s not as sparkling clear as it was. Pool size 20x44 rectangle, 33,000 salt chlorinator. I have a pentair 1 1/2 hp variable speed. 2 skimmers and three returns: I run the pump 24/7 2hrs 2200 RPMs, 10hrs 1300 and 12hrs 175 RPMs (at night).
PH is 7.8 - it took 1 drop to get to ideal 7.6
CYA - this is my problem and question. I tested as directed with the small bootle filling to 7ml then add drops to 14ml. I mixed, waited 30 seconds then pour in tub with my back to the sun using my shadow from my body looking straight in the tube. I continue to see the black dot all the way pouring to the top. Its faded I think but I can still see the dot. I retest using the same sample pouring back in the bottle waiting 30 seconds. Same results.
How can that be that I have no CYA when opened in just a little over a month ago (May 15th) I added to bottled of liquid stabilizer.
Went back to the pool store to retest. Stabilizer was good.
Is this normal for stabilizer to disaster? I was told once it’s in it in. How much should I add?
