OK people, I'm about to do my first official SLAM after studying posts on this site. My pool levels are pretty on point for the most part but my phosphate level is at 500 which is why I feel like algae keeps coming back on the walls within 2 days of scrubbing, despite having high FC levels (8ppm).
The pool shop suggested that I add PhosFree to remove phosphates but after studying on this site it sounds like i just need to SLAM it. Let me know if I'm on the right track. Here are my readings as of last night:
-FC: 8
-PH: 7.6
-TA 70 ( I added 2 lbs of baking soda this morning to raise this)
-CYA 80 (I am in Austin, TX and my pool gets full sun so I think this is fine but tell me if it's too high)
-Phosphate 500
-Current Pool temp 85 degrees F
Water is clear but Algae grows quickly on walls. 14,000 Gallon plaster pool
Pool math suggests that I have a FC SLAM target of 28 PPM. I am using 10% liquid Chlorine and I will be adding 4 .3 gallons of liquid Chlorine. Is this what I should be doing or should I just go with the PhosFree stuff to remove phosphates?
Thanks!
-FC: 8
-PH: 7.6
-Phosphate 500
Thanks!
