- Jun 16, 2023
- 10
- Fiberglass
- Jandy Aquapure 1400
This is my first winter for the pool. In my area it is rarely possible but can hit single digits. This is a fiberglass plunge pool of 2,500 gallon with gas heater, salt gen, plumbed for few spa jets and has a couple actuator valves. The two valves I am questioning if I can leave closed are a hydrostat valve the builder put in to pull water from outside/around the shell in a massive rain event (labeled 1) and a drain valve with actuator that would take water out of the pool (labeled 2). I have the spa jet valve partially open (the other actuator). Thinking there will be no water above ground on the closed sides of these valves. Is this OK?
Thanks
Thanks
