I've recently attempted (and failed
) to make one of these. Our pool is much larger, though, and I believe it requires one solid piece of pipe.
We were able to successfully couple two pieces of 2 inch EMT conduit, using a compression fitting. It sagged with fitting alone, so we took a 5 foot section of PVC and filled it with spray foam insulation (deck spindles work well too
) and placed that at the joint for stabilization on either end. It worked pretty well joining two pieces together - 4 notsomuch. Since you really only need 2+ a little, it would probably work ok for you too. It's that joint that needs the extra support.
