Well, I FINALLY got it all dialed in!
For the past week now my FC has remained perfect without me having to manually dose the pool... It looks a bit redneck at this point, but now that I have the placement of everything worked out, as well as the dosing schedule for the pump to run... I'll be working at a better permanent placement for the components this fall... going to re-level the pool, install a new liner, and build a deck at the same time.
5Gal bucket to hold the bleach with the 1/4" feed line running from the bottom of the bucket to the pump (Hanging from the post behind the pool filter)
The yellow bucket is acting as a cover so the timer stays dry (I am using an indoor timer that can do up to 28 separate on/off settings )
Under the bucket, I placed an empty flower pot upside-down to keep the timer from resting directly on the pad (In case of flooding during a hard rain).
here is a pic of it dosing the pool.
All in all, I have it set to dose the pool 5 times a day, for 5 minutes each time... seems to be just about perfect!
My pool pump runs on low 24/7 during the season, and the volume of bleach that gets dispensed at any time is small enough that I don't see any problem running it directly into the skimmer. (But I might be wrong on that).
Many thanks to the OP for this idea!
