I have a MX8 vacuum. Recently had it rebuilt was doing circles. I also changed the sand in Tagleus filter. I have about 12 PSI pressure which i believe is normal. The vacuum moves slowly now, i have to nearly close the valve to get it to move. The store took vacuum and tested said it worked fine. I have backwashed same thing, put on recirculate no change. Any help with this please
Kevin
Kevin
