It all started when I made the mistake of thinking there was just a lot of pollen in the pool ( It wasn't)
Water was clear but FC levels started to drop and I thought I had a cell problem (Again, it wasn't)
I tried to run the cell at 100% for a few days and was unable to make a rise in FC levels (my goodness I can be a slow learner!)
After reading all the info I could find on SLAM/Mustard Slam, I started that process on Friday.
Started with
FC 0
CYA 60
PH 7.2
Ca 350
TA 75
Temp 84
I raised FC to 24 for 24 hours and then took it to 36 for another 24 hours. Did the ODPD test last night/this morning and it fell to 32 overnight which is indicates that the little yellow brats are still hungry and still with me!
I'll add some more liquid chlorine this morning but won't be able to watch it as its a workday, but I'm going to presume that at these FC levels that close monitoring is less of an issue?
Once I pass the ODPD test, what's the recommended way to get the FC level down again? Just leave the SCG off until it falls?
Also I'm going to recommend that anyone with a SWG system do a ODPD test before they think the cell is failing, it would have saved me a ton of time!
Started with
FC 0
CYA 60
PH 7.2
Ca 350
TA 75
Temp 84
