They told me to exchange water by draining by putting the pump on the first step and draining to the step and refilling. We need to redo the process multiple times. They recommended for decreasing cyr levelPools can pop out of the ground when drained, so make sure to consult a local professional expert to make sure that you can drain without floating the pool.
Is it a serious problem? Should I be worried?The two main copper stains are turquoise and gray to black.
Turquoise stains usually happen first.
The turquoise gets turned black by chlorine, especially by calcium hypochlorite.
How copper goes up and crest such a problem?Your plaster was probably originally white and now it has a turquoise color.
Two-Year-Old Pool Major Discoloration and Bleaching
Hi, Everyone! New to the forum and to pools in general. Closed on a house with my first pool! Yay! Although it's only two years old it has major discoloration (light and dark spots). General home inspector thought it was algae but the water is so clear. Here is what the prior owners...www.troublefreepool.com
They put chlorine tablet on floaters and we just replaced the heater since the previous one was leskingCopper can come from a heater, algaecide, some chlorine tabs contain copper, ionizers, mineral cartridges etc.
The heater contributed to the copper levels.we just replaced the heater since the previous one was leaking
Do you think that I will be able to solve the issue by exchanging the water and using Home / Stain Program / STAIN SOLUTION #2 – The Copper & Scale Stuff?Pools can pop out of the ground when drained, so make sure to consult a local professional expert to make sure that you can drain without floating the pool.
How can I do that?Possibly.
You have to take the heater out of the system during the treatment because the treatment dissolves copper.
Possibly.
Should I add the chemical when the pump is off and mix it by brushing or vacuuming?Possibly.
