If you clean the cartridge filter in the detergent solution that is normally used to clean it, that should get rid of the algae, but to be sure I'd put back in the clean cartridge while your chlorine is still at shock levels.
Snowymoon said:The pool is wonderful. ........ I just check it occasionally and add bleach here and there.![]()
