Hi all. I have noticed what appears to be mustard algae clinging to the shaded wall (I let the chlorine level run low so it's my fault). It was yellow in colour and easily removed by brushing. The water is still clear. I'm following the SLAM procedure using liquid chlorine.
1. Is there any risk of fading my blue vinyl liner at mustard algae shock level, which in my case is 39? I found one relevant thread which had me concerned:
www.troublefreepool.com
This thread reassures the user that SLAM levels are safe for vinyl liners, but no mention of mustard algae shock levels:
2. Is the 24 hour mustard algae shock absolutely necessary or can I maintain SLAM level and monitor over time?
3. I thought CC was an indicator that chlorine was being consumed, but my CC is always below 0.5. Is this normal?
4. This might have contributed. My SWG max setting (i.e. the number of LEDs that light up) changes. Sometimes it only winds up to 70%, then next I look it is lit up at 100%. It is no longer consistent. What could cause this?
5. Do I need to run the pump overnight? What about during overnight chlorine tests?
Here are my current levels, thanks!
pH 7.7 (never changes, although I did just add acid aiming for 7.2. Generally it always sits at 7.7 and I can't maintain lower than this. I think because I regularly top up with tap water because I don't have a cover and evap is high)
FC 23 (will increase to 28 tomorrow or as recommended here)
CC <0.5
CYA 70
TA 125 (never changes)
CH 250 (never changes)
Salt 4900
So it looks like I bleached my Vinyl Liner during my Mustard Algae SLAM
I had to SLAM my one year old pool after getting mustard algae. When I started the SLAM, my CYA was at 65 so I brought my FC levels up to 26 until I passed the CC and overnight test. Then I raised my FC to 37 for 24 hours for mustard algae. I went out of town for 4 days after the mustard...
Risk of bleaching liner with SLAM?
FC 7.2, pH 7.6-7.7, TA 90, CYA 50 (CYA from pool store electronic test) I have an algae problem and need to SLAM my pool. Based on the chart Chlorine / CYA Chart - Trouble Free Pool and my CYA level (which I find impossible to test myself as I ALWAYS see the little black dot!), I need to bring...
CC <0.5
CYA 70
Salt 4900
