I’m in Spain and the only Muriatic acid I can buy here is 20%
Up till now I’ve been estimating how much to add, basing my guess on the “effects of adding Muriatic acid 31.45%” in the drop down menu on the app, and I’ve had reasonable results as I’ve only been adding it a litre or so at a time to reduce the pH.
However I want to add borax to my pool water. I’ve been reading up on it and understand about adding MA to balance out the pH and the TA.
My problem is I’m not so good at math and because I’ll be adding a lot of MA I was hoping there might be some math geniuses here who can help me work out a formula to convert 31.45% to 20%
Up till now I’ve been looking at the 31.45% figures and calculating that 20% is roughly 2/3 of 31.45 %
So when I add 2 liters of acid the change will be a reduction of 0.6pH, instead of 0.9,and this is in the ball park of what I’m actually producing, usually my results are a little less ~ a reduction of 0.5
Is there anyone here who can help me work it out more exactly?
Thank you
Thank you
