Tonight I decided to pump a small amount of water to waste in anticipation of heavy rains predicted for the next 36 hours. I will be away from home during the storm so wanted to make a minor adjustment.
Pump off. Set my multiport valve to "waste". Routed discharge line to a good spot. Started pump.
Pumped for about 5 or 6 mins to reduce water level about 1 inch or so.
Pump off. Move multiport valve back to "filter". Pump on.
Looking at the pool, I saw a brief "puff" of what could only be DE come out of one of my return jets. It stopped quickly. I let the pump run for another 10 mins or so, watching the returns, but that was the only DE I saw.
So what gives? None of the water should enter the filter when pumping to waste, right? I'm confused as to how I got some DE in the return line - it suggests that there is some (unintended) connection between the waste line and the internals of the filter - problem with the multiport valve?
This could explain a strange observation I made a week or so ago - I pumped a substantial amount of water to waste during a drain/refill to reduce CYA. I refilled the pool and restarted the pump/filter. A few days later I dismantled the filter to clean the grids, but I found there was very little DE inside the filter when I opened it. I was confused by this since only a month prior I went through a complete dismantle/clean/recharge DE and I was VERY careful to measure out the factory recommended amount of DE. Maybe there's some kind of problem with the multiport and running it in "WASTE" mode sucked a bunch of DE out of the filter and down the drain. Anyone experienced this before?
I'm leaving tomorrow and trying to decide now if I should add some more DE to my Pentair FNS 36, just to be sure there's some DE left in there!
