Hello. I have a master temp 400 about .w years old. It powers our pool and spa in the summer and only the spa in the winter.
This week it started throwing an HLS error as soon as it gets to 100 degrees. At which point it shuts off the gas/heat, seems to reset, try again, heat for 30-60 seconds, then repeat.
The googling I’ve done says it could be water flow, however it will heat from 70-100 without problem. It’s just when it his 100 it starts shutting off.
Other results said it could be insufficient gas. But again, it heats 70-100 just fine.
Could the high temp switch really be bad after only 2 years?
Anything else I could test/try?
Thanks.
Thanks.
