Hey all,
Learning a ton here. Love it.
Still seeming to find conflicting information regarding MPS and it's ability to impact CC (apart from it potentially interfering with test results).
I saw this quote on a previous thread on the same topic, " Use a combination of MPS and chlorine in the off-hours to try to bring the CCs down to a manageable level. This will require some trial and error to figure out."
Does MPS lower CC in a system that is using a dichlor/bleach system?
If not, how does one go about lowering elevated CC in such a system? Is there a way to do this aside from water change? If I've understood correctly it sounds like by performing a chlorine shock with bleach there is some potential for reduction of CC but I'm trying to get a grasp on how that mechanism works. I'd picture the chlorine shock oxidizing all of the potential substances and organics within the system that are eligible for oxidation, but wouldn't this just drive CC up even higher in the short run? Is the idea that it drives it up higher in the short run but then the CC's naturally dissipate and there is a reduced rate of CC accumulation but everything was oxidized during the shock?
Appreciate any insight you all might have. I'm a long time hot tub user who has failed to find good answers to these questions over many years and I finally have hope I'll get a good answer.
Dan
Dan
