Hi All,
So I'm at my wits end here with my potential suction side leak and I'm hoping someone can help...
First let me start by saying that my pump basket has never filled up completely to the top. I also knew there was a leak, or more than one leak, somewhere in my pool as it was losing a substantial amount of water every night.
That being said, the leak was located in the spa structure and return line, so I have just had my pool remodeled/re-plastered 2 months ago. I've only lived in the house for 6 months now so all this is new to me.
Once all this was completed, my pump basket still didn't fill up all the way to the top. It gets over the basket... but never all the way to the plastic window on the top of my pump.
Okay, thought there still might be a suction side leak somewhere but my equipment pad had all plumbing running through the concrete so locating the leak, if it was at a 90, wasn't really an option. No big deal because I wanted to move the equipment anyways and I just did that.
I have a new drain line coming from my spa and a brand new vacuum line, that I never had before, running to my equipment. The skimmer line is mostly new, but there is a run of about 6 feet under concrete that I didn't feel like replacing due to the cost. But like I said, the spa drain line and the vacuum line are brand spanking new and definitely DON'T have leaks.
Equipment pad move was just completed yesterday and when the equipment was fired up I thought for sure the pump basket would fill to the top... but it still doesn't. I've tried switching the intake, on my brand new Jandy valves, from solely the spa drain line and solely the vacuum line to see if this would fix the problem as I know they are tight as a drum at the moment... but still only 2/3 of the way full.
Most of the plumbing on the equipment pad is new... but not all of it. You can see in the attached pic, anything that is still a grey line was on the old pad. I'm thinking that the union connections to my pump, or the pump lid, must be the culprits at this point... but obviously, I'm still not sure.
I did lube the heck out of the lid basket o ring and the union o rings with silicone lube, but that didn't fix the problem. granted that was before the equipment move, and I'll try that again but I suspect that won't help at this point.
My contractor says it's this way because my lines are only 1 1/2 inch suction and returns and the pump has 2" unions and that the pump just isn't getting enough water to fill the basket to the top. I thought there was a chance he might be correct, but after reading other posts on this forum I now know that he is not correct.
I'm thinking of buying new/replacement unions and a new o ring for my pump basket lid and having those installed. But if there was an air leak there, wouldn't water slightly drip out at some point? I don't know, I can't think of anything else. My filter is old. My backwash plunger thing is old and sometimes leaks so I'll replace the o rings on that... but theoretically those shouldn't affect the suction side, correct?
Anyways, sorry for the long post but wanted to include as much info as possible.
Anyone else have any thoughts/ideas?
Thanks for reading.
Thanks for reading.
