The IntelliFlo might be a good choice for you.
For IntelliFlo, you will need to make sure that the wiring is at least #12 AWG for wire runs up to 100 feet and #10 AWG for lengths longer than 100 feet.
I’m still concerned about the voltage drop at the motor. You can get an inexpensive clamp on amp meter to check the amps.
I think that the voltage drop is going to be either the motor drawing too much amps or a problem with the wiring.
I wouldn’t put on a new IntelliFlo if there is a chance that the wiring has an issue. I would suggest getting a new breaker. I would suggest Pentair part Number PA220GF (2 pole 20 amp GFC) if it will work in your box.
I would suggest having an electrician replace the breaker, add a surge protector and check the wiring.
Then, once the power is correct and verified, add the IntelliFlo.
In your first post, you say that the motor is only 2 to 3 years old. It should not have failed this fast. I suspect that the power supply might be the cause of it not working.
The main reason I suggested having the motor checked was not to repair it, but to determine if it was the cause of the voltage drop.
If the motor checked out ok, then it would definitely point to a power supply issue.
A diagnostic fee should not be too much. How much did they want for a diagnostic fee?
