Motor overheating
Airsick
Active member
Jul 5, 2019
36
Odessa, FL
Hey, Guys. I recently replaced my 1.5 HP motor on the Hayward SP3010X15AZ unit. All plumbing is 2" serving a normal 15,000 gallon pool with spa water feature. I opted for a single speed
ouyanglong UST1152
(generic AO Simth) motor with a service factor of 1.0. Nameplate FLA is 9.3, but to get down to that I had to close off the suction too much, so I let it run quietly on 10 amps. After less than 2 months it started internal overload tripping. I hoped I could replace the thermal switch, but I couldn't find it, so I put the motor back together with a new impeller and hoped for the best. I chose a 1HP impeller hoping the motor would run cooler, which it did for an hour, then it started tripping again, even though I could get it to only draw 9 amps. I was able to get a refund for the motor, but I don't want to keep replacing motors. From what I've described I hope others will have some advice as to which way to go on a new setup.
I would drop the impeller down to a SPX3007C or even a SPX3005C.
The SPX3010C should not be drawing that many amps.
Can you show a picture of the impeller and the part number stamped on it?
Does the impeller spin freely or is it binding?
Did you verify that the voltage is good under load?
This pump looks like it has been leaking for a long time.
20230926_130543-jpg.532615
That is about 2126 watts.
I would expect closer to about 1,500 Watts.
Since the amperage is within the label, I would file a warranty claim for a replacement motor.
I would drop the impeller to a SPX3005C unless you need a lot of flow.
The pump is drawing more amps than it should be and this happened before in your other thread from
The total power draw should be a maximum of about 1,650 to maybe 1,850 at the highest.
2126/1,650 = 1.3 time too much power draw.
So, something is off.
Check the frequency and power factor.
Maybe the start capacitor is not being removed from the circuit due to a defective centrifugal switch?
This shows that there was some interference between the impeller and the diffuser.
Maybe you are getting some interference or maybe the seal is in backwards or something.
Do you have this impeller ring? SPX3005R.
Maybe see how the motor runs without being in the housing.
