Date of installation?Have a 3/4 HP motor which is one year old.
Start of last year pool season. Warranty expiredDate of installation?
Heater valvesAre the valves set correctly?
It looks like both valves are closed blocking flow completely?
Checked skimmer and drain. I have good flowIt looks like all flow is blocked?
James. I have never checked a motor under loan at terminals. Could you explain the process of how to do this? When you say under load, do you mean with motor running? Thank youThe max load amps is 10.6.
Maybe an oversized impeller or maybe the voltage is dropping out.
Check voltage under load at the motor terminals.
But if I shut the valve just a little bit I still have pretty good jet, flow and circulation. The pump does not get hot and shut off.My nephew is head of maintainance at a local college here in town. Has electrician license. He checked at terminals under load. It is good. I’m thinking impeller now. It ran 7 hours today with pressure side valve open all the way. Like I said earlier sometimes it’ll run an hour sometimes two or three sometimes up to seven or eight hours. I just don’t understand it. I think impeller is my last option.
Ok thanks. I still have enough flow with valve shut a little to run heater. I will check impeller when I get time and let you know model. Appreciate your help a lot.More restriction reduces the flow and that reduces the amperage.
Check the impeller.
You can reduce the impeller as long as you still get enough flow for the heater.
Or, you will need a bigger motor.
Is that in back where back casing comes off? Because nephew and I are going to take off Friday and use 12 gauge chord and wire it to terminals and plug into another outlet to see if motor gets hotCan you show the wiring compartment?
