Here is my pump and filter set up. Just opened my pool today and my pump motor is bad. There are several things wrong with it and I have been limping it along for a couple of years. This set up is 15 years old.
I am trying to go cheap as possible. I am moving in 4 years and don't want to spend a grand on an entire new set up.
I found this on the interwebs
It feels like the easiest choice. It is an exact replacement. I should be able to swap it right out correct?
My questions
1. what HP pump do I need? I cant read the old motors rating.
2. I could go with almost any pump and motor correct?
3. I would just need to adjust the plumbing if I went with another motor?
4. If I order this part onlime, it will take a week to get to me. Do I just use a sump pump to run water through pillow stuffing until the pump is installed? My pools is green.
5. I tried to get the unions off that connect the pump to the plumbing and I could not get them to move. What is the trick to removing them? Is there a tool?
