- Jun 8, 2020
- 590
- Plaster
- Pentair Intellichlor IC-40
I finally got the ScreenLogic setup installed yesterday, and am going through it, trying to set things up in a convenient way.
I have an EasyTouch PS-4 (with SCG integration) and a waterfall. Right now, it's setup as follows for the AUX and FEATURE circuits:
With pump speeds as:
For schedules, I have:
So the pump runs 24/7 at 1500RPM, then runs high speed at 2500 RPM for one hour int he AM (8am - 9am), and the waterfall runs at 2800 RPM for one hour in the evening (7pm - 8pm).
I'd like to have a way to trigger the waterfall to run in a low flow mode, as well as a high flow mode though. At first, I thought I would accomplish this with two AUX buttons ... one for low speed pump and one for high speed pump, and both actuating the same valve. But from what I can tell, valves can only be assigned to a single circuit ... so that idea is out.
My next idea was to have a single waterfall button, and just remove the pump speed (2800) from that circuit. And then have one of the AUX buttons assigned to the pump's "Pump High" circuit ... so in this way, the WATERFALL button would just actuate the valve, and it would flow at whatever the pump speed happens to be. So for waterfall high, you would have to also press the HIGH SPEED button .... but, I think I'm out of physical buttons to use due to have a PS4 instead of a PS8..
So a couple of questions:
On the PS4, is there a way to assign a FEATURE circuit to one of the 5-8 buttons? I believe these are strictly for the additional AUX circuits on a PS-8, but thought I'd check just to be sure. If I'm right, and I can't use these for anything on my PS4, then this may convince me to convert my PS4 to a PS8 by adding the 1k resistor to R42.
Next question is related to the 4-BTN SPA SIDE remote functionality ... Is the spa side remote a simple 4 button remote, where each button ties to one of the pins on the terminal block within the ET-4? And then a function gets assigned to the button? If so, could I add additional buttons (DIY style), wired to the spa-side terminals, and then select any circuit I want for each one? In essence, providing 4 additional physical buttons for activating/deactivating FEATURE circuits?
So connecting additional DIY buttons (latching or momentary?) to the SAP-SIDE REMOTE 1 terminal block:
And then assigning a circuit to the added buttons here:
If I can repurpose the SPA-SIDE remote functionality like this, then it may be a good way to create something user friendly for the wife and kiddos.
