Hi all. Reporting in from Houston, TX., safe and sound, thank god. Harvey was a *bleeeeeeeep* but we survived. Small hole in the roof which ruined the ceiling in the guest bathroom, but it's hard to complain about something like that when we see what happened around us.
Grand total here was around 44", which meant that during the storm (usually at uncomfortably late hours of the evening) I was outside draining my pool. 5 times. Test results show what I suspected, which is I probably swapped out half of my water between pumping and the rain refilling it. Everything is roughly 50% of what it was pre-storm.
FC: 3
CC: 1
PH: 7.4
TA: 50
CH: 130
CYA: Did not test. It was too dark out by the time I got to it tonight. It was ~45 pre-Harvey
Temp: 78 (brrr! It was 93 pre-Harvey)
I just added a bottle of bleach to bring FC up to 7. The water is clear, and I've been doing a good job skimming debris out of it. But the DE filter didn't run for almost 6 days - it's on now, and I'm going to leave it on for 24-48 hours. I'm hoping I don't have to SLAM, since bleach is in fairly short supply around here. I plan on retesting FC in a little while and then again in the morning.
On hand I have: 4 or 5 gallons bleach, stabilizer, ~20 lbs of hardness (Leslie's brand), and 1 gallon of muriatic acid. Pool math is telling me I need to add 162oz weight/129oz volume of baking soda, and 511oz weight/408oz volume calcium chloride (hardness). I don't know when I'll be able to get ahold of that much baking soda, and I'm confusing myself online reading about soda ash vs baking soda (leslie's sells soda ash - are they interchangeable for my purposes? I think I could get to leslie's tomorrow sometime, but that's a TON of baking soda to procure when there are lines outside supermarkets just to get in)
My plan tonight is to start adding the hardness that I have, and try to get more tomorrow. But the TA is confusing me. Can someone help and tell me if (1) soda ash from leslies is ok to raise my TA, and (2) am I heading towards recovery or SLAM?
FC: 3
CC: 1
PH: 7.4
TA: 50
CH: 130
