- May 31, 2012
- 854
- Vinyl
- Jandy Aquapure 1400
I have a minor leak somewhere in my pump - see the attached photo. I only noticed it because the concrete under the pump is always wet in approximately a 1 foot diameter. I realize that sometimes there is a leak when the pump is started or stopped, but the pump has been on for over 24 hours with no rain. The leak appears to be around the centre of the pump as the water is evenly distributed in all directions, it doesn't seem to be coming from one side or the other. There is no visible flow of water so I think that this is a very low volume leak. The leak does not appear to be on the union from the intake or outflow. Could it be a crack in the overall pump? How do I diagnose the problem, or can I just let it be since it seems to be such a minor leak?
I thought that the source of the leak could be the drain plug, so I tried to tighten the drain plug, which is plastic, and when I was doing this the plug broke apart, but the threaded part is still in place. The leak does not appear to be coming out of the drain plug, but now what do I do? Do I have to fix this? My pool is closed up by a service in October each year, but I am not sure if they take the drain plug out. Do I need to fix it or just leave it like this? Do you need to use the drain plug? Or can you just use a shop vac or sponge to get rid of the water when closing?
