Almost five years ago I replaced the thermistor in my Minimax NT pool/spa heater. It had been working fine. Once again I was getting the HI code on the display. I was not at all surprised given the arctic conditions we had here in Texas.
I knew what to replace so I order up the part and replaced it. After replacing the part and leaving all the panels open everything was working fine. Heater fired up fan ran good. After about 10 minutes I shut everything down and put the panels back on. Now I am not getting any power to the Minimax. The orange/white connector on the back of the control board is not showing 24v. So, I am thinking that maybe an internal to the heater protection device was tripped. Is this possible?
Also, another observation is that after this no power to the heater occurred when I switch the pump back to pool via the automation the main pump shuts off. Don't know if this is connected but a data point to share.
Thank you.
Thank you.
