I'm new to the forum. I had to install a new variable speed pump with all new plumbing. Since it's been finished my MS-10 salt controller only reads "No Flow". I had to rebuild the contoller T valve and I'm thinking the sensors are not deep enough in the T valve to get a good water reading. Can the wire that passes through the Hex Nut on the top of the valve be moved without damaging anything? Does anyone have any experience with this problem?
