Now that you have confined the stain is from iron, you need to consider the following:
1. What is the source of the iron? Those who are on a well get iron easily, but even some on city water find elevated iron levels in their water as well. For others, it may be old plumbing that adds iron. But you need to know in order to prevent adding more iron to the water. Otherwise, it's a futile battle.
2. It would be ideal to lower the iron content by exchanging with fresh water.
3. Existing iron stains can be removed a couple ways. If the stains are sporadic and just in a few small places, Vitamin C is fine. If the staining is widespread, you may wish to consider an Asorbic Acid (AA) treatment.
4. Remember that iron staining shows itself due to the following condition - alone or in combination with each other:
a. An iron level over 0.3 ppm (try a free pool store sample to confirm)
b. An elevated pH level; the higher the pH the more tendency for iron to precipitate and stain
c. An elevated FC level; same as with an elevated pH causing the iron to stain
See the following links for more tips on stains and AA treatments.
The stained pool is beyond embarrassing. Our in-depth Guide to remove stains in your pool will help you to remove the stains and prevent them in the future.
www.troublefreepool.com
