I have Iron in my water and had staining. Did the Ascorbic acid treatment added Polyquat, sequestrant, some of the stains lifted. I must have other stains that are not organic or metal but one problem at a time. My question relates to the natural tendency of my PH to rise. It takes a lot of muratic acid to keep my PH at 7.2, it will settle at about 8.2 if left alone. If I understand the instructions, if PH and Chlorine are high metals precipitate back out. So... if I need to shock I should bring the PH to 7.2 and keep it there as long as the chlorine is high, but other than that is it ok to leave the PH high as long as the chlorine is at normal level for my CYA? Then a follow up question would be to over winter, do I need to keep adding sequestrant all winter? A PH of 7.8 is not too hard to maintain during the swimming season and the CSI is much better at negative .01.
Current (finished muratic acid treatment and PH is rising on its own)
chlorine 0
PH 7.5
TA 80
CH 230
CYA 40
CSI .3
chlorine 0
PH 7.5
TA 80
CH 230
CYA 40
CSI .3
