Helping with a pool. It is an AG 18k gallon, 24 foot round. When they called me their pool was cloudy. Homeowner also mentioned that they had metals in their pool and had the CuLator in their skimmer basket. Pool was so cloudy I couldn't see past 1st step. Upon 1st test which was about a month ago these were my readings.
FC - 0
CC -0
PH - 6.8
TA - 100
CYA - 110 + it was off the charts
CH - 90
There was no visible algae. I got it cleared up with liquid chlorine, and raised PH to 7.3 with two boxes of borax. The pool however does not hold chlorine so I am constantly adding. I would think with the high CYA it would be holding plenty. Today I added one 121 oz of chlorine at 11am, came back at 4pm and no chlorine. I have not tried an overnight test as they do not have a kit. So I am using my k-2006 when I stop in. Homeowner has stopped using pucks and we are doing our best to handle high CYA with out draining.
The other issue now is with metals. When I first started helping them, the Culator was clean, once I raised the ph it turned reddish brown, along with the cartridge filter. We had to clean it twice. It was terrible red/brown.
So that leads to my main question - if algae is not causing the major chlorine loss, could it be the metals? Today I noticed the pool had a slight yellowish tint on the entire surface. I called a Culator rep and he called back and felt loss of chlorine was from high CYA, but that didn't make sense to me. I understand CYA reduces effectiveness, but didn't think it would cause actual chlorine loss. I don't want to SLAM if it will cause metal staining - but want to get to the bottom of chlorine loss.
Any help in troubleshooting is greatly appreciated!
Thank You!
FC - 0
CC -0
PH - 6.8
TA - 100
CH - 90
Thank You!
