- Aug 1, 2016
- 38
- Vinyl
- Hayward Aqua Rite (T-9)
I have had some issues for the past few years with metals, staining and keeping balanced. Got a TF100 kit this year and want to quit the pool store after wasting so much $ and still having issues! With TFP I think I’m on track. Water appears to be balanced after almost a week of fluctuating FC and I am now holding stable.
FC 5
CC .5
PH 7.5
CH 350
CYA 40
Have been adding only bleach 8.25% for 4 days. I did add 1 qt of Iron Out II on Sunday as recommended. Water is now clear, no major pressure rise in the filter has stayed around 18psi. I did add a CuLater to the pump basket to try to capture metals. My last metal test from 6/29/19 done at pool store was .5 copper and 0 iron. Prior to that test I had 4.0 copper and 1.4 iron. Got that down with Iron Out II recommended by the company that installed the pool. I have done AA treatments in the past with immediate good results that fade fast after the metals release back into the water and when chlorine is added back in (I was probably doing it too quickly). Want to do AA treatment again as the pool looks terrible and no one wants to use it! Looking for advice on the best way to treat the stains the TFP way. Thank you all for your help and guidance through this process. I have learned so much!
FC 5
CC .5
PH 7.5
CH 350
CYA 40
