I am trying to put together a weekly maintenance plan for my pool and want to see if I'm on the right track and what everyone else would recommend.
My pool has copper in the water which I am currently sequestering with ProTeam's Metal Magic which is a great product and does a great job of lifting the stains and sequestering the metals. However I know I need to be careful with chlorine levels in the pool even with the metals sequestered. Too much chlorine and the metals will come out of solution and too little chlorine and I risk an algae bloom.
So I think on a regular basis I will try and keep the FC between 1 - 3 and the pH between 7.0 - 7.2. When it is time to add more chlorine to the pool, I'll add a maintenance dose of Metal Magic. I was also thinking of using a PolyQuat 60 algaecide on a regular basis if the chlorine levels are low in the pool to prevent algae from growing.
Just wondering if this is a good plan and if I am missing anything. Last week my chlorine levels dropped to 0 and I added enough liquid chlorine to raise the FC to 3, however this caused the metals to come out of the solution, so I am thinking of adding less next time and adding the Metal Magic before adding any chlorine as an extra precaution. Maybe only raising it to 1-1.5 at a time and going from there.
