Hi All - I had time to use Jack’s Magic and a chlorine puck to see if they’d remove the stains.
Unfortunately, there was no noticeable improvement. Since the stains are in water 6 feet deep or more, it was hard to apply the test, but I believe I did it correctly. I’m unsure if the stains were supposed to disappear or just lighten?
I had the water tested—no significant iron or copper, and all my chemical levels are good. The stain isn’t raised or rough to the touch either.
Any other ideas? The stains are mostly at the base of the deep end walls and where the pool transitions to the deep end. Otherwise, no other staining.
