Hi there. Does Jandy SWCG in your signature stand for salt water generator?
If so, some sequestrants do not work as well in high TDS of a saltwater pool. I don't know much about GLB, but if you're swg I'd try Jacks Magic Purple, which is more agressive with iron. (Jacks pink is most aggressive for iron if you're not swg...its about 60% phosphonic acid.)
Secondly, IF you're swg, you can be adding trace amounts of iron in the salt that's oxidizing in the swg cycle. This coupled with plain ole rain might be enough to have caused it to build up. While your soil might not be blowing in in any huge quantity, it does seem suspect that you have other soil staining and I have seen cases where iron in the soil ends up in the water
In your case, I feel it would be worth having an iron test kit -- and then reporting back the ppm. Those are relatively cheap.
There was a poster here a few years back called Small Pool Dad who had a constant metal struggle due to the iron content in surrounding soil. He tried various things, including a highly complicated hydrogen peroxide treatment which I also attempted to replicate.
My recollection was that to stay stain free, he simply had to keep a level of 28 ppm or higher in sequestrant. Again, thats a pricey kit when its "obvious" when sequestrant has worn off, so I'm not necessarily suggesting one.
If you had the iron test kit, I'd test your fill water too, regardless of whether you're city or well. That will also help determine a next step...if the fill is clean or even lower than ppm in pool, its worth dilution. If not, its not, and then it might be time to look and some extra mechanical filtration -- eg a greensand filter plumbed in (metal trap makes a larger one for autofills) or maybe some on-return filtration via Slimebag (
The Slime Bag | The Easiest Way To Maintain Crystal Clear Pool Water. )
In the xperimental vein, since you have a sand filter, there's a product called FerriTab that is polyacrylate, which kinda flocs out oxidized iron via filter...this might be worth a try only when the sequestrant looks worn off as in my experiment it didn't appear to do a lot when the water was highly sequestered.
There is also a process of adding calcium via the skimmer in very specific circumstances that has been reported to reduce iron, but I never tried it and I haven't been able o find that thread again for a few years. I will try to take another look tomorrow after some assue gardening gets handled
Lastly, controlling ph to the low side, eg 7.2, should help. Hope that gives you a few idea to start kicking around. Will check back to hel refine strategies
