What can I use to suspend the cooper in the water and not cause it to add more stains to the vinyl. I guess they make some sort of liquid for doing this?
Seeing that my cooper level is high should I drain some water down and refill?
Regards
W&C
W&C
I was just reading another post with metals in the water and I really don't want you to have to go through all of this
Metal stain removal, sequestrant... stains return in about a week... repeat.
Matt will have to add to this and tell us if it is worth doing but this is really the best option to clear all of this up and have a truly trouble free pool, and please if anyone see's this or think this is the wrong way to accomplish this, please let me know... Right now this is just a discution on a plan of action, so don't do anything yet..
The plan:
I really want to bring your FC to SLAM levels and have you scrub your pool and stains and turn your pool green as can be, hopefully this will dissipate all your copper in the water and not on your liner
Then drain 1/3 of your water, leaving at least 1 foot in your shallow end, then refill, then empty a 1/3 out again, and then do it again...
This will use the most water but in the long run I think it will be the safest and best possible route to clearing your stains, getting the copper out and getting you to a better pool overall..
what do you think about this plan and using all this water, it will take some work on your part and I am not sure the best way to get all the copper in your water to start the drain but we will work on this...
Casey
