Metal Pool Coping Loose
Aced63
2
New Jersey
Hi everyone! As a new pool owner, this forum has been invaluable- so thanks in advance for the advice.
I recently purchased a home with an in-ground pool. We had it inspected by a separate, pool-specific inspection company, and the only issue they brought up was the coping: it's loose on one side (see attached picture) It's an older pool with metal coping that's definitely seen better days.
I haven't seen much information about this type of coping- i'd like to at lease secure it, and possibly replace it (if possible- the pool has a brand new liner, which I understand would need to be replaced during a coping replacement)
Has anyone seen this type of coping, and any advice on how to proceed? Thanks!
Does the coping have a liner track in it? can't tell from the images. I am guessing it does. If it doesn't than you could replace the coping, but it will likely end up meaning you need to redo the patio/decking around the pool match the top of what ever coping you replace it with.
If you have a new liner, I would say live with it and start saving for when you need a new liner and plan for redoing the coping and anything else. I did that, ended up replacing all the skimmers, returns, plumbing, electrcical and the decking around the pool and most of the backyard. Scope creep. It started out as a liner replacement and replacing the coping!
  • Wow
Reactions: YippeeSkippy
