- Aug 1, 2016
- 41
- Vinyl
- Hayward Aqua Rite (T-9)
Hi,
1st post here, but looking for advise! Have a 23,000 gallon vinyl pool with SWG. A couple of years ago started getting some metal staining. Used stain free from nature’s chemical and got great results although some cloudiness at times. This year was no exception. Pool opened and within a week metal stains were back. Went to 2 local pool stores each giving different readings and advise. Used the stain free again looked gorgeous after a few days of cloudiness. Went away for a few days and came back to greenish water with stains back. Added some Algaecide based on another recommendation and waited 24 hours no change. Went to the company that installed the pool and they tested for me.
Total chlorine- 0.0
Free chlorine -0.0
PH- 7.8
Total alkalinity- 113
Calcium hardiness- 0
Stabilizer- 5
Copper - 4.0
Iron - 1.4
Salt- 2100
Phosphate- 2000
They advised me to clean my filter, add 1 qt to start of Omega iron out formula 11 and then use the stain free that I already had. I did this and the pool looked gorgeous again. They told me to come back for testing prior to adding a chlorine back in to recheck for metals. 3 days later I did here were my readings.
Total chlorine- 1.0
Free chlorine - .2
PH - 7.5
Total alkalinity- 157
Calcium hardness- 177
Stabilizer- 35
Copper - .4
Iron-0
Salt - 2103
Phosphate- 806
They suggested 2 qts Omega Iron Out Formula 11 then 2 gallons 38 oz liquid shock or 2lbs 5 oz super shock granular. I added 1 qt of the iron out and within hours pool got cloudy. Have not added any shock or anything else for fear of restraining based on past experience. Cleaned the filter and have been running it 24 hours for 2 days. Still cloudy. Want to use the pool, and desperate to clear it up HELP
Total chlorine- 0.0
Free chlorine -0.0
PH- 7.8
Stabilizer- 5
Copper - 4.0
Iron - 1.4
Salt- 2100
Phosphate- 2000
Total chlorine- 1.0
Free chlorine - .2
PH - 7.5
Stabilizer- 35
Copper - .4
Iron-0
Salt - 2103
Phosphate- 806
