Last year when we opened the pool there was a ton of leaves in the pool. I see them in there again now. Is this normal? Or do. I need a new one? It looks sealed Tight so not sure where they get in from
The leaves are from the strong winds and coming from outside to underneath. You could use water bags all the way around and this would solve your issue, but an expensive one and time consuming. If the leaves do not create any type of stains, then I would just let it go through the winter and clean in the spring as there should be a minimal amount of leaves that enter the pool.
If I watch mine on a really windy day the edges flap a little with the big gusts. You could try weighting the edges down with bags of sand or water. I just deal with it.
