Measuring Pool for a Robot Cleaner
poodlegirl
0
77
Baton Rouge, LA
When measuring your pool to figure out what robot cleaner you need, do you include the coping in the measurement? I'm right at the cut off point for the Dolphin E20. I'm measuring between 32 & 33 ft long. That measurement includes the coping.
I'm not understanding why you need to measure anything. What is telling you that? As long as the robot cord is long enough to traverse the pool from your outlet, you're good.
Reactions: proavia
PG,
A lot has to do with where your AC out is located.. The power supply needs to plug into the outlet and pretty much stays right next to the outlet. The cable on the robot must be long enough to reach from the power supply to the farthest point of your robot can go while in the water.
