Reviews of this cleaner say it is a very effective cleaner, but their customer service and tech support is worthless. After much research, I discovered the controller pulls 2 amps, yet no one at their company has any idea how many amps are pulled when the cleaner is operating. The closest I can get to an outlet is 12 feet away, so I need to use an extension cord. I could go to the trouble of adding another outlet (which would still mean the power has to run an additional 12 feet), but I don't want to go through the hassle, and that area would be less protected from the rain. I want to use a 12 foot extension cord from the GFCI outlet running under the eaves and securely attaching to the controller's input cable. I have a 12 foot 14 gauge extension cord I could use. Maytronics say an extension cord is not recommended, but there would be no difference between adding a new outlet and the extension cord, other than the house wiring is 12 gauge rather than 14 gauge. 14 gauge wires are rated for up to 15 amps. I assume the cleaner's <29 volt DC motors (based on the rating of the cleaner's power cable) won't pull anywhere near the additional 13 amps during startup or while running, but I thought I'd run it by the experts on this site before I actually install it. A 1hp DC motor only pulls 9.5 amps, and I can't see how these small motors would produce anywhere near 1hp. The recommended extension cord (up to 25') for my heavy duty Bosch 15 amp jackhammer is 14 gauge. Any help you can offer would be appreciated.
