I am replacing my heater with a Max-E-Therm 400k BTU heater. (Same electronics, etc as a MasterTemp 400, but was a tiny bit cheaper and DW likes the rounded shape better than the boxy shape)
As part of that, I have plumbed in a bypass valve so that I can bypass the heater. And I put a valve actuator on it and hooked it up to the heater control board.
I have an EasyTouch 8 automation system (with ScreenLogic so can control from phone/tablet)
I've found that EasyTouch doesn't speak RS-485 to the heater.
I didn't realize that until after I had everything hooked up and was searching online to try to understand what's going on.
So I've switched over to the 2-wire (firemans switch).
With the fireman's switch, it basically powers on/off all the heater controls - the heater's screen goes blank when the fireman switch is off.
And that means the bypass valve stays with the water going through the heater after the heater turns off.
If I use the heater control panel, pressing the "Heater off" button, the heater goes into "Heater Cooldown" for a while, then moves the valve.
SO:
The heater has a "3-wire control" option as well as the RS-485 and 2-wire.
I read the 3-wire control basically replaces the spa/pool heat on buttons.
My understanding is that there are 3 wires - a "pool", "spa", and "common".
If you short "spa" to common, it's like pressing the spa-on, if you short "pool" with the common, it's like pressing the "pool-on" button.
My question is - is it a continuous connection or momentary?
Do you have to keep "spa" and common connected for it to keep going on the spa heat?
Will the heat turn off if you break the connection? (And go through the cooldown phases, etc?)
OR is it really like pressing the spa button? ie. you connect common and spa for a moment and it will keep heating until it hits the temp requested or someone hits the "heater off" and only then will shut down.
I'm hoping it's continuous - that making the connection is like hitting the "Spa" button, and breaking the connection is like hitting the "Heater off" button.
IF that's the case, then I think I can hook up the "Spa"/"Common" to the "Heater" connector in my ET8.
And that will provide me with everything I want. The bypass valve will move properly (plugged into the heater circuit board) And the water temp will be controlled by the ET8 closing/opening the "heater" connector.
SO:
