Figured I would post here rather than start a new thread. Having a temp issue where the water is reading about 20 degrees higher than actual - 82 degrees when it's actually 55-60 degrees. So when we turn on the heater, it only heats to about 80 degrees (reads 100). I just changed the thermistor thinking that was the issue but still the same issue.
Any thoughts on what I should check next? Everything works fine other than the system turning off when it thinks its at temp b/c of the incorrect reading.
