A recent lightning storm surged some but not all of my equipment. My easytouch 8 panel is semi-toast and is getting replaced (upgraded to intellicenter). While its on order, I am manually running the filter pump which thankfully still works. I want to run the mastertemp 400 heater. When I turn on the panel, it starts up as normal for about 2 minutes before it gives up and just displays 12:00am. During those two minutes if I put it into spa mode, the heater will come on, fire up, everything is fine. But when the easy touch shuts off, the heater turns off... fine.
Then I turn the breaker off to the easy touch, leave the breaker on to the heater (which is also the breaker to a purifier ozone/uv thing, which lights up fine), have the pump on at 3000 rpm (lots of flow for the heater's flowmeter) but the heater doesn't turn on. Nothing on the display. Hitting pool on or spa on does nothing. Any ideas?
