Hello I recently came home to my pool being heated on its own. The heater seems to be continually on. (and the vent air seems to be unusually hot as well)I can turn it off but then it clicks back on several seconds later again. So the only real way to have it completely off is to cut the power at the breaker. When the power is on, The temp read out jumps from seems to be the correct pool temp (about 65) to then like 250 then 100 and back to 65. After reading some other posts I disconnected the ribbon on the side of the control board to see if that made a difference but the heater still came on with that disconnected. Any thoughts? Thanks
