Any help or ideas are appreciated here.
Opened the pool today. Everything went smoothly and is operating as it should with the exception of my Mastertemp 250.
The unit is firing. Heat is being exhausted the coil housing is hot, but the water is not warming at all. I called the company that installed the unit - and they said it was normal at this time of year and to let it run over night - sounded odd. Pool temp is 54 right now. I’ve set the temp to 70 just to see if I can feel warm water through the jets - but it feels exactly the same temp as the pool after a few hour of running. After some research could the internal manifold bypass be stuck closed? I do not have an external bypass. Am I risking destroying my heater here by taking their recommendation?
Any help here would be appreciated.
