Master Temp 400 O-Ring P/N
Plankton
94
Hi All,
My Master Temp 400 outlet O-rings are leaking. This is where the slip coupling attatches to the connector tube on the heater. I looked at the parts list in the manual and cannot see these O-Rings. After looking a bit more I see a set for the coupling, slip coupling and the O-Rings, the P/N is PKG188. I have searched and found the slip coupling and coupling P/N but I cannot locate the O-Ring P/N at all. The closed I have come to what I think it is would be a U9-362. I can't believe that I have to buy a whole coupling set just for a couple of O-Rings. Has anyone run into this problem or can anyone confirm the P/N that I found for the O-Rings are correct? Any help would be greatly appreciated. Thanks in advance,
