- Mar 5, 2017
- 603
- Plaster
- Hayward Aqua Rite (T-9)
Haven't seen much talk or specific posts about the older Master Pools Turbo Clean in-floor cleaning systems, so I'll share my experience.
I did much research with the help of some amazing customer service at aamfg.com & pool supply unlimited, and discussed between Turbo Clean heads or the A&A manufacturing's retrofit 'sprinkler' style. Was able to get quotes for $120 for each TC head while the A&A heads (with retrofit collar) was $50 per head.
I actually bought the house without any clue as to what these holes in my pool were. Neither did a pool guy and home inspectors! Previous owners abandoned the system. The outlet valve didn't change stations (gears were ground flat) so it didn't make sense and there isn't much info online, though TFP was the most helpful so I want to give back.
Now that I've repaired the 5 port Valve (thanks again to aamfg.com), and installed A&A retrofit heads, I can't be happier. No more dealing with stuck pool cleaners and trying to swim around the hose. I do need to brush the walls more frequently, and manually vacuum every other month, but that's about it.
I've attached before/after images. I will say I've never experienced the Turbo Clean heads, and haven't heard any experiences...anyone on here have? Is the water distributed evenly over the circumference with the TC? I like the pressure of the A&A heads, but it does take 2 hours of high speed pump time (I Have a VS pump) to hit each station and turn 360 and kick up all the dirt on the pool floor. It's been 18 months and so far no issue, but I'm sure the heads will fail-but I'd rather pay $40 for a new A&A head than $120 for a TC head. Maybe the TC heads will last longer?
