Hello and Happy Spring Opening to All:
I have posted about this issue before, and here we are again.....the old thread was discontinued so I'll create a new one here:
I have noticed over the last four years (including recently when I opened my pool) that our "raised overflow waterfall spa" surface on both seats and vertical walls is very pitted when we pull the cover off in Spring. 2000 gal capacity approx. The rest of the pool 22,000 gallons is smooth. Last fall I removed almost all the water in the Spa except about 12 inches. When closing I drop the pool 4 inches below the tile and use a pump as needed when it rains thru the mesh cover.
When I opened yesterday, the spa was about 2 inches below the tile line...having filled with rainwater over the winter.... which is exactly my plan so I do not need to place a pump in the spa (only the pool) to keep the tile from contacting ice. So far, so good.
When closing in late Fall I take good care to balance the pool & spa.....and then SLAM. The water is very clear in the Spring. When spa water was tested at the opening I saw the pH was off the charts high, deep purple (as usual) ....the FC/CC was 0 of course. I did not test for other parameters, just added a tiny bit of MA acid to get to 7.4 and a couple of sprinkles of 73CAL Hypo. Cleaned out a little debris and fired up the pump / filter to circulate the spa. The water looks great. FC=4 and pH around 7.4.
A couple of days later I got in the spa and noticed the pitting on the marcite was about as bad as ever. Mama wasn't too happy, ruins her bathing suit..... This is now the fourth year of this situation...so I thought I'd reach out to the Forum again. Last two years I used a Lava stone to flatten out the rough peaks in the pitting. I am now going to try a light wet sanding block with a fine grid of 220 or higher...as the Lava Stone is ground up quickly and is gone in no time.
So, I am asking: is there something I should do before closing each year? During the winter?
Two theories;
I am wondering if because the rainwater has a very low calcium content that it causes the pitting when it slowly fills up over the winter? Does this make sense?
Or is it due to the super-high pH measured when I open? This is discounted because the pool has the same super high pH and it does not pit. And becuase the rainwater contribution to the pool is much less in terms of the percentage of rainwater added to the total existing pool water.
Ready to break out the wet sander block!
Puzzled. Is there a solution to stop the pitting over the winter months?
Thanks!
Two theories;
Thanks!
