If anyone if interested, figured i would share how i did my setup which is working great for me.
Reason i did this is because my ProLogic board could not do what i needed it to do with the valves.
I needed something simple. When my Spa pump is on, the GVA24 was turned in diection2, when the Spa pump is off the GVA-24 was turned in direction1.
For me its with a 240v pump. Should work the same with a 120v.
This guide describes how to wire a GVA-24 - 3-wire actuator using:
- Honeywell AT72D1683 24VAC transformer
- Hawkeye H908 current sensor
- RIB2401D dual-pole relay
The GVA-24 uses the following wire roles:
• Black = Common (24VAC return)
• White = SPA (open valve)
• Red = POOL (close valve)
GVA-24 Valve Wiring Guide
Overview
This guide describes how to wire a GVA-24 - 3-wire actuator using:- Honeywell AT72D1683 24VAC transformer
Transformer: Honeywell AT72D1683
Terminal | Color | Connects To | Purpose |
H1 | Black | 120V Line | Primary HOT |
H2 | White | 120V Neutral | Primary Neutral |
R | Yellow | RIB Yellow & Purple, H908 COM | 24VAC HOT |
C | Purple | RIB White/Yellow & Valve Black | 24VAC Common |
Hawkeye H908 Current Sensor (Set to NO)
COM | White | Transformer R (24VAC HOT) | Power input to relay trigger path |
NO | Blue | RIB White/Blue (coil +) | Relay energizes when pump is ON |
Sensor Ring | — | Pump L1 passes through (Black or hot wire only) | Detects current draw |
RIB2401D Relay Coil Wiring
RIB Wire | Color | Connects To | Purpose |
Coil + | White/Blue | H908 NO | Energized when pump is ON |
Coil - | White/Yellow | Transformer C | 24VAC return |
RIB2401D Relay Contact Wiring
Contact | Color | Connects To | Purpose |
Pole 1 COM | Yellow | Transformer R | 24VAC input to Pole 1 (SPA) |
Pole 1 NO | Orange | GVA-24 White | SPA (valve opens when ON) |
Pole 2 COM | Purple | Transformer R | 24VAC input to Pole 2 (POOL) |
Pole 2 NC | Gray | GVA-24 Red | POOL (valve closes when OFF) |
GVA-24 Valve Wiring Roles
Wire | Function | Connects To |
White | SPA (CW/Open) | RIB Orange (NO Pole 1) |
Red | POOL (CCW/Close) | RIB Gray (NC Pole 2) |
Black | Common | Transformer C |
