I have a Polaris 280 on a booster pump. I would like to look at supplementing it with a manual vacuum. What can I get to be able to clean up the fine dust and dirt that gets into the corners or on the steps? My cleaner does not do the steps and not so hot in the shallow end. I would like to be able to spend 30 mins to manually clean that up before parties if I forget to run the Polaris Long or it’s just dirty. I also have some DE I think left in the pool to clean up from before I had a tear and the screens replaced. The Polaris does not seem to picking up or its spitting through the bag.
So I need a vacuum head for my pole ( I can use my brush pole?)
Then hose
Something that helps couple to the skimmer?
My pool has 3 skimmers and 2 main drains. I think I can switch the main drains off from these jandy valves
Intelliflo so I can crank up the water flo
Then hose
