Hey Guys,
So I had my pool replastered last year and they replaced the main drain cover. This year I opened the pool and everything was fine then I noticed a sudden lost of water at a very fast rate. Water was at mid skimmer line around 6pm and the next morning it was 3 in below the skimmer bottom. I looked around the pool for puddles of water and such and I found behind my pool shed where by backwash line comes out of the ground above it there was water flowing out at a steady rate. I filled it back up yesterday thinking it was the main drain and I plugged it and the skimmer line to rule those two out.This morning same thing the water was 3-4 in below the skimmer bottom.
I called a pool leak company and they wanted $395 for a dye test and $695 to test using a listening device. Before I agreed to those terms I looked around the pool again since it was about 10 hours since I last checked and the water has not went any lower. I noticed that the pool water stopped right below one of my return lines. Should I have the leak detection company still perform those test or should it be easier to find the leak now that the pool water stopped dropping at one return line?
