My SWG salt level detector went bad, causing the system to shut down due to what it says are low salt levels. Based on conversations, I think the manufacturer may try to get out of a warrantee repair because I said I tracked the CSI instead of the LSI. They are also harping on phosphate and TA, and CH levels not being in their specs
FC - 33
CC - .5
PH - 7.2
CYA - 85 (a little high)
TA - 80
CH - 50
Phosphates (when pool was green)- 500,000 ppb (through the roof)
Copper - .8 ppm
Iron - 0 ppm
Temp - 85
I opened late too a swamp (my screw up). After completing my SLAM, I’ll measure the phosphates again to see where I stand. At this point I don’t know if I will worry with it unless it causes me to use too much FC trying to keep up with the nasties. As I have a vinyl pool, I don’t worry about CSI because it never gets to a level where I have to worry about corrosion.
