Hi all,
I've been dealing with high Total Alkalinity and have attempted to lower by adding acid (muriatic) down to 7.0 and then aerating. This was only able to lower the TA from about 150 to 110. TA then went up to 120, and after coming back from a 3 week vacation t has gone back up to 150. Do I just repeat the same procedure again, or is there something I'm missing here? I had been getting a lot of crystal flakes from the inlet to the pool, which has reduced significantly after this first attempt but the TA is still high. My recent test were FC 7.0/CC 0.5/pH 7.6/TA 150/CH 450/CYA 40/Temp 81/Salt 3050. CSI is at 0.3, I don't really see much signs of scaling, just the flat crystal flakes. I also have the SWG to shut down about 15 min before the pump to try and prevent flakes and I recently acid washed the SFG.
The other issue is the CYA is still low at 40. When I checked it before I left on vacation it was also around 40, and then I added about 5 lbs of dry CYA (into skimmer inside a fine mesh bag) and was expecting it to be much higher when I returned but still stuck at 40. The pool has an auto cover. I'm going to add more CYA again, but this seems really unusual so wanted to ask the experts on the forum.
Thanks!
Thanks!
